That Eagle-Aspen is a very unreliable rotator, as the amount of current that can be sent up the coax cable is very limited, and it won't turn a decent-sized antenna with any degree of reliablilty. You would be much better off using a separate rotator cable as used by a Channel Master 9521a or an AntennaCraft TDP-2. If you have a very large array, you may also want to consider using a Hy-Gain AR-40 instead, which is a much heavier-duty rotator at greatly increased cost.
