It looks like you can get a full line up of programing if you aim a http://www.solidsignal.com/pview.asp...0Antennas&sku= or similar antenna toward 233° per your compass. The CW network affiliate on real channel 5 is a duplicate that will not be received well. (KNVA - 49 is much closer)
Mount outside at 20' AGL or greater with a preamp like http://www.amazon.com/Winegard-HDP-2...2219326&sr=1-3 . Then RG-6 from the amp to a ground block http://www.amazon.com/F-Type-Groundi...2219058&sr=1-5 adjacent to your electrical service ground.
Then rg-6 to a passive 3 or 4 way splitter and then RG-6 to each receiver. Terminate any unused splitter port with a 75 ohm F-terminator.
I'm sure there are several other good recipes out there... Welcome
