First & foremost. You need to remember that an amp will only *push* signal through the cable. It will *not* help the antenna suck in more signal That's not the way it works.
The other point. VHF means both Hi-VHF ( 7-13) and Lo-VHF (2-6)
Look at the frequency charts & the various dipole calculators. The numbers you mentioned ( 6 & 31") are correct for uhf & hvhf, but the lo-vhf stuff from Philly is going to require a dipole roughly 9 feet across for channel 2.
You simply can't fight physics, no matter how hard you try.
Gain in any one direction will be offset be loss in a different direction.
Elements resonate & receive at a certain size. Other sizes are *significantly* less efficiant.
Agaian. we really need a link to your tvfool report.
