Thanks for the reply. I'm debating whether to use a tripod on the roof or a 1 1/2" pole that would pretty much be the same location, mounted to the house. Can the pole also be used as the ground or should I use a separate ground rod? I'm going to use the existing dish network wiring. Can I use the dish network solo node as a splitter or do I need a dedicated splitter?
Thanks so much for your help, I appreciate it!
