Check the input switch on the amp. They're usually in the wrong position from what the directions say, plus they're pretty flaky. If it's in the "Separate" position, then your results are expected.
I wouldn't expect WEAU to be picked up with only one panel aimed that way.
Please run the individual panel tests i earlier requested.
