Old 11-Jul-2014, 7:31 PM   #6
KUTH (Univision) does not own or operate any translators. They got approval back in 2012 to move to Farnsworth Peak from that mountain just across the lake from Provo. I've never heard if they completed that move.
Your TV set is a hybrid model that was common during that very short time frame. The set has TWO F-connectors on the back. You have to be certain that you are using the upper one (the lower one is for cable only). If you happened to hook up to the CABLE input, you'll get some very strange results when you scan. Please check that.
