Old 11-Jul-2014, 4:43 PM   #5
germm
Weak UHF signals are readily blocked by close-in obstacles such as buildings and trees.
I can try a different edge of the home to see if it has a better angle. I can increase the size of the mast also, if needed. I wasn't able to added length to the mast last night because of a lightning storm.
Is that the 3ABN station (K43JV)? If so, the tuner is set correctly to "antenna" and the antenna and cable is working. Is that station analog or digital?
The only station I receive is 32.1 (Univision) which has a repeater on the mountain behind our home. I cannot see repeater on the TVFool analytic page, but I can see it from my window.
How old is your TV set? If older that 2007, what is the make and model?
The TV used was produced in 2006-2007 area. I have other options, but this tv is closest to the antenna. It is an LG 42LC2D
http://www.cnet.com/products/lg-42lc2d/specs/
I have a new tv I can try, if you believe this is the issue. are there any tricks to tuning the DB4e? The pre-amplifier I am using is a PA-18.
germm is offline   Reply With Quote
