Quick information update.
I'm using an HTPC with a win7 TV tuner, a Hauppauge model.
Using Window Media Center, it is able to scan for signal strength, and is giving me strong signals for all channels above 10, and poor/weak signals for those under 10, namely 4, two at 6 (HD and SD) and 8.
I was now considering a preamp, the CM 7778 as an easy fix (roof install is a pain for the moment). A friend suggested the roof interferes more with lower frequencies, resulting in my current situation.
If that doesn't work, I'm getting the roof redone later in the summer, maybe I can use the guys while they're up there to put up a mast and the antenna.
