My home sits lower than one of the homes and higher than the other. I do have homes, about 30 feet higher than ours, in our reception path. Shouldn't be enough of an obstruction to receive at least one or two channels
Weak UHF signals are readily blocked by close-in obstacles such as buildings and trees.
but I can only receive from the transmitter behind our house.
Is that the 3ABN station (K43JV)? If so, the tuner is set correctly to "antenna" and the antenna and cable is working. Is that station analog or digital?
How old is your TV set? If older that 2007, what is the make and model?
