Old 13-Dec-2010, 3:22 AM   #2
Unless you have metal siding or foil faced insulation, I would recommend a set of rabbit ears... Non-amplified
For example: http://www.amazon.com/Terk-Technolog...2210417&sr=1-1 or http://www.amazon.com/RCA-ANT111-Bas.../ref=pd_cp_e_3
However you say you prefer an outdoor antenna so you may want to consider a non-amplified 'omni' like http://www.solidsignal.com/pview.asp...0Antennas&sku=
The predicted signal levels at your location leave you plenty of margin even if you need to split the signal to several sets.
Nice line up BTW
