Old 11-Jul-2014, 2:03 AM   #3
tv454481
Thanks for the response.
The tv is a Samsung UN40C6500VF. The splitters that I've tried are the CDA4, a passive Ideal 4-way 5mhz-2.4ghz model 85-334 that I picked up today at Lowe's, and an Antronix 4-way CMC3004H 5mhz-1000mhz that used to be used with our cable connection. I've tried adding F terminators to the splitters to no avail as well.
Any reliable way to measure signal strength at the antenna and elsewhere? Also, would grounding have anything to do with it? I'm wondering if I have the DB8e grounded correctly.
Steve
tv454481 is offline   Reply With Quote
