Old 11-Jul-2014, 12:24 AM   #1
tv454481
Confused by results, could use advice
Hello,
http://www.tvfool.com/?option=com_wr...e1c68299b93eb2
I've been gradually upgrading antennas from indoor to outdoor, finally ending up with a DB8E roof mounted, about 25' AGL. Along the way I've also been learning about UHF, Hi-VHF, VHF, and a bit more here and there.
I currently have the DB8e pointed just west of true north with a 50' cable run into the house and then another ~25' to the TV that I'm using to test with. I pick up WSAW, WAOW, WHRM, and WFXS but only when I run direct, with no splitter, preamp, distribution amp, or anything. I'm confused why Hi-VHF is being received on a UHF antenna and then why I can't use a splitter (I've tried two different ones.)
If I attempt to put the antenna output into a basic splitter I get no signal. I also attempted to put it through a CDA4 powered distribution amp and it works on one of the outputs but not another... Talking to Antennas Direct they believe the CDA4 is bad.
My question is: What's the next step? I have an RCA TV1PRAMP (or similar model number) which I picked up based on reading these forums. Will a preamp be more appropriate for my situation or will a distribution amp work better? Why is Hi-VHF coming through? Finally, any advice to pull an NBC signal? That's the only major network that I'm missing.
Thank you for any advice.
Steve
tv454481 is offline   Reply With Quote
