Old 10-Jul-2014, 8:24 PM   #2
Are you aware that the FCC has rules that protect your right to use an antenna for reception of over-the-air TV signals? http://www.fcc.gov/guides/over-air-r...n-devices-rule These rules bar the HOA and local municipality from stopping you from installing and using an antenna.
I would concentrate on Louisville signals. Even with a very large antenna system, reception from distant markets will be sporadic... At best.
If we were neighbors, you'd likely see a Winegard HD7694P above my roof, pointed at about 295°. I'd try using just a passive splitter. If this test, http://forum.tvfool.com/showthread.php?t=13646 proved the need for amplification, a Channel Master CM-3410 distribution amplifier can easily be added between the antenna and splitter.
