Old 10-Jul-2014, 7:09 PM   #3
lbs22
Your TV Fool reception report strongly suggests that you need to consider using the largest availble antenna or combination of antennas that cover the UHF and High-VHF bands.
Several choices I would consider are;
Winegard HD7698P
Antennacraft HBU-55
Antennas Direct 91XG + Antennacraft Y10713 + a UHF/VHF combiner (separate or built into the preamp)
An RCA TVPRAMP1R or Antennas Direct PA-18 would be the preamps I'd consider.
Since I'm just trying to boost a signal that comes in strong and clear 90% of the time, could I just try a preamp? Considering the Winegard LNA 200. The existing large antenna is very large like the links you provided but at least 20 years old. Do most antennas have model info on them somewhere?
lbs22 is offline   Reply With Quote
