Old 12-Dec-2010, 10:48 PM   #5
Originally Posted by Tigerbangs View Post
My suggestion would be to use a 2-antenna installation of a Winegard YA-1713 VHF high-band yagi plus an an AntennasDirect mounted on the same mast 4' above the YA-1713. Combine the signal from the two antennas using an AntennaCraft 10G221 high-input preamplifier, and use a rotator like a Channel Master 9521a or an AntennaCraft TDP-2 to turn the antenna array.
I concur with Tigerbangs... I suspect the Antennas Direct model he refers to is the 91XG http://www.solidsignal.com/pview.asp...u=853748001910
Please correct me if I'm wrong TB
