OK - so it's probably just a case of wave diffraction causing all kinds of interference. I'm guessing my best bet is purchase something like a Winegard HD-9032 antenna and point it directly at 110 degrees, and if I can't get FOX with that then it's basically hopeless. Is that a reasonable assumption?
Assuming I can get FOX with that (and assuming it does not bring in everything else), then I can try combining the two antennas as was suggested earlier.
The HD-9032 seems to have the best gain near FOX (15.7 at channel 50) and is reasonably priced. Is there any other antenna I should consider before going this route?
By the way - thanks all for the help.
David
