Old 4-Jul-2014, 12:28 AM   #24
kenj66
Thanks for the reply, ADTech. I was thinking of posting here in the appropriate forum. Some of us are not mechanical geniuses! For example:
Step 1.) When I assembled the boom I noticed the boom wasn't straight. Scratching head, I noticed that I had pushed the boom ends into the matching clamp but the screw head was UNDER the clamp instead of on top. A line ought to be added saying, "Be sure the screw heads appear on top of the clamp instead of underneath." I was simply following the directions! They didn't say to untighten the clamp first so the screw head would be on top. It never occurred to me. Did I mention I was not a mechanical genius?
Step 2.) Place the balun box - which way? In which hole?
I didn't notice the thumb screw in the materials when I did this and instead, undid the screw and wingnut from the end of the boom, discarded the wingnut and attached the balun box with that screw - backwards, as it later turns out.
After stumbling with these instructions, trial and error, it seems to me the assembly steps are out of order. I think the order should be steps 1, 4, 3, 2, 5,6.
It makes more sense to do step 4 after step 1 because the instructions do not tell you exactly where the tilt bracket should be installed. The location of the tilt bracket can only be properly determined after all the directors are installed. And then the orientation of the balun box becomes more obvious, too.
Just got my mast sections. Need to go to Rad Shack for some guy wire hardware.
kenj66 is offline   Reply With Quote
