I decided to purchase a Winegard HD8200U
Probably not a desirable choice. It's HUGE (it has low-VHF elements you have no use for) and it's too directional to pick up both cities reliably without using a rotor. Because it's so massive, you'll either need to spring for a very heavy duty rotor or be prepared to replace the rotor frequently.
You can try aiming it at the weaker signals and see if you get the stronger ones off the side, but results will be unpredictable. You'll have to try it and see.
