I looked at your TV Fool report, saw that the bulk of the signals fell approximately within that range of azimuth.
You should always fine tune the aim to maximize reception reliability. Use the signal metering function of your tuner if it's equipped. Check all stations of interest to you to be sure that you've not made one worse while trying to make another better. It can be an exercise in compromise.
