Old 12-Dec-2010, 1:24 AM   #2
Dave Loudin
You can edit out your address if you want, your report is fine. I would use exactly none of the antennas you listed, as the PBS station is on ch. 7. You need a very modest high-VHF/UHF antenna, such as a Winegard 7694P, AntennaCraft HBU-22, or RCA ANT-751 aimed at the network stations due east. You could try the Terk HDTVi indoor antenna if you can take it back if it doesn't work for you.
