I'm on the 2nd floor of a two-story building.
My balcony faces SW, so I will try and point the antennas as much as I can more-towards Mt Wilson.
If I do change the antenna direction to point directly where my compass directs me to, I would need to point them to the walls out on the balcony where my water heater and extra storage space is.
I was trying the keep the antennas out in the open and not pointing towards anything that may block a signal. I guess it is worth a shot to try. Once I did update and change my RG6 cables things got a little better signal-wise.
Do you think I should combine both the C4 and C5 cables together before I send one combined cable through the preamp so both antennas get preamped? Because right now only the C4 is going into the preamp and after that I combine both the C4 and C5.
I'm going to go out and see if I can switch things around and combine it all before I preamp tomorrow.
