Old 29-Jun-2014, 1:57 AM   #1
Chevy power
Norton Ohio Antenna questions.
I do not watch much TV and I have netflix. I would like to get an antenna and mount it to where the existing dish was mounted on my roof. I took the dish down last weekend, I can use the J pole from that (ideally I would like to or I can fabricate a higher post if needed). I currently only have two TVS but as time goes on I plan on having a few more. I ran new Coax to my existing TVs and have a cheap rabbit ears that I put in my attic.
Can someone recommend an antenna for me and my location?
Ideally I would like the antenna in the attic but would much rather prefer maximum channels over not having the antenna in the attic. So I pretty much ruled attic mounting out.
Right now I have a feed line from the rabbit ears to a splitter to my two TVS. I would like to set this up correct for 4 or 5 tvs while I am doing it. Can I just use a splitter?
Here is my signal analysis
http://www.tvfool.com/?option=com_wr...e1c66018b138c6
Thank you for any help. I appreciate the wealth of information on this site.
Chevy power is offline   Reply With Quote
