Old 27-Jun-2014, 5:52 PM   #4
cumak
Thank you both for your replies.
First, I didn't realize my first signal report was at the block level, but I updated it to use the exact coordinates. The link in my original post has been updated, and the results got slightly better (no more 2Edge paths for the signals I'm interested in).
Next, i didn't mention in my original post, but I have lots of tall trees behind my house, in the direction the antenna is pointing.
I don't believe that the gain is too high, since if I was overloading the tuner I'd expect to see the signal strength pegged at 100. I generally see numbers in the 70's or low 80's.
You've both provided helpful insight, but what I'm really wondering is with my situation, is it likely that I will find a "sweet spot" that will always provide stable reception? Or, are things always going to be changing based on the weather, season, alignment of the planets . I've already observe the optimal angle for one channel is not necessarily the same as for another channel (broadcast from the same location). And the optimal angle seems to change by a few degrees day to day. When ADTech states "sometimes, a mere 6-12" of movement can make or break reception", will that precise location change day-to-day also? I DVR most of my shows, so I can't use a rotator.
For the channels I'm interested in (generally 500 MHz - 650 MHz) the 91XG is spec'd for 13-16 dBi gain with 30-40 deg beamwidth. Would I better off with less gain and more beamwidth? With the DB8E, for example, I could point the elements to get something like 5-12 dBi with more than 90 deg beamwidth. Would this provide more stable reception for me under (presumably) varying signal propagation conditions? Or would that just be a waste of money?
Thanks again for your help.
-Mark
cumak is offline   Reply With Quote
