Thread: What equipment
Old 27-Jun-2014, 5:13 PM   #2
Based on the path profile links in your TV Fool report, it looks as if there is a significant hill or mountain south of your location. This obstruction reduces your available signal levels and quality. Given the size of the antenna needed, I would consider using a more substantial mounting than a satellite J-pole.
I would use a large UHF/H-VHF antenna such as the Winegard HD7698P or Antennacraft HBU-44 or HBU-55. An RCA PRAMP1R preamplifier would be needed also.
You will want to mount so that as the antenna is pointed toward the south, it's not aimed into trees buildings or other nearby obstructions. I'd consider using a tripod or chimney mount.
