Originally Posted by LynnOnTheWeb
Thanks for the information.
Would changing to a directional antenna make the need to trim the crepe myrtles unlikely?
I simply can not guaranty the final result... Trees can be quite problematic and they can have a varied impact on the signals. You may need to trim the trees and replace the antenna.
Which step is the least costly from your perspective? If you are equipped to trim the trees, have the time and desire, then do that first. If you have to pay someone to do all the work, that may change the order of steps.
Reason: sp.
