Old 26-Jun-2014, 10:43 AM   #8
bob schalow
signal strength for one channel?
I installed the HD7694p antenna and it seems to work good. I got local channel 2, 7, 9 and about 57 other channels. I have been told by some that 2 is one of the weaker signals in my area.
The small problem is channel 5 (5.1, 5.2, 5.3) comes in but is glitchy. Is this more antenna adjustment or do I need to amp up the signal?
My mast might not be quite high enough because the antenna doesn't completely clear my roof peek. is Which of the above is the likely fix?
bob schalow is offline   Reply With Quote
