Old 11-Dec-2010, 4:07 PM   #2
Originally Posted by drslingshot View Post
Heres the link to my map information http://www.tvfool.com/?option=com_wr...81a3fc780aba7a
Any suggestions for antenna type and height are appreciated. I have equipment and skill to install as needed with regards to height etc.
Most will suggest a rotator in your situation. That will work with a HD8200U, HD7084P or CM 3671. Channel 5 will be a challenge. Get the antenna as high as possible. Use a 7777 preamp.
If you want to avoid a rotor here's a second option:
Get one of the 2-69 antennas aimed at 110°.
Add a 91XG aimed at 328° and use an A/B switch.
Each antenna needs it's own preamp.
