Old 24-Jun-2014, 1:03 AM   #4
You don't need any of those combo antennas as they all have the wide, low VHF elements that won't be needed in your area.
You likely also don't need the HBU11. A DB8e (or a DB8) should pick up a VHF 11 signal that strong. If not, we now have a simple VHF kit that clips right onto the reflector for the 'e' series bowties and our UHF loop antennas.
Fox is available on one of the Orr translators.
The RCA pre-amp is adequate.
