Old 23-Jun-2014, 8:37 AM   #1
rockroll
Need antenna(s) suggestion for San Rafael, CA
http://www.tvfool.com/?option=com_wr...e1c6c949219782
Want channels at 165-166 degrees from San Francisco (Sutro and San Bruno Towers) and also prefer Sacramento (Walnut Grove) channels from the east 71-74 degrees. I briefly tested with Clearstream C2‑V and GE 24792 from my East facing 3rd story balcony. Depending on -random- angle, I was able to receive channels from San Francisco, Sacramento and even from San Jose/Fremont area.
I can put several antennas in attic (asphalt shingles roof), but would not like installing very long antennas like AntennaCraft Y10-7-13 - hard to point to specific direction.
I would run about 50ft long coax from attic to basement where I have existing runs to 4 rooms (another 30-50 feet).
Ideas that comes from reading various forums, but not sure how much feasible:
1. For UHF – bowtie two panels Extreme Signal HDB8X or AntennasDirect DB8E. Point one panel to San Francisco, and another to Sacramento. Angle between the two about 90 degrees. For VHF: Clearstream C5 or AntennaCraft Y5712 60" and pointing at (not sure). Combine these with UVSJ, and then boost with variable gain pre-amp like 10G212.
2. Use single panel UHF bowtie like HDB4X or DB4 to San Francisco, and UHF Yagi type (Like AntennaCraft MXU47) to Sacramento. Combine these antennas with 1:2 splitter reversed. Use Clearstream C5 (or some other VHF antenna) pointing to Sacramento?? And use UVSJ diplexer to merge VHF and UHF. Pre-amplify combined signal??
Thanks in advance for any suggestions.
Roof install is not an option.
rockroll is offline   Reply With Quote
