Old 22-Jun-2014, 11:43 PM   #4
Before giving up, I'd do as already suggested... Move the existing full size antenna outside to a location that has minimal obstructions such as buildings and trees.
Is your TV capable of tuning DTV signals? Or is it an older analog only set?
The Mohu Leaf is not likely to have the needed gain or the directional capability needed to overcome the multi-path and similar problems due to the edge path conditions you face. If I was starting from scratch, I'd use an all channel antenna such as the Winegard HD7084P, Antennacraft HD1800, 1850 or Channel Master CM-3018, 3020. I'd definitely mount outside in the clear.
