Yes, the entire structure is concrete which is why I thought putting a leaf in a window may be a better solution.
I took a tested piece of coax and tried the leaf outside with the converter box as well as directly connecting to a digital TV. Channel search found nothing in both the front and back of the house.
I just don't get it. The coax is good, TV is set to ANT, and I run a channel search after moving the antenna to different places. The digital converter box rules out any issue with the test TV as it's made to receive digital signal and has RCA out.
