Old 22-Jun-2014, 4:00 PM   #3
mazr
Thanks for the reply, Stephanie. I have a fairly clear line of sight to the SE. When I had the antenna pointed north, it was maybe 15 feet off the ground and I got OK signals. If I hooked it up to the chimney pointing SE, it would be about 25 feet off the ground so I don't think the 2 trees would be an issue. Now my other question: my chimney is not an exposed one, it's covered with wood siding. Would the chimney straps work on that?
mazr is offline   Reply With Quote
