You are not in a deep fringe area.
Have you tried your setup bypassing the amp? Simplest place to start. I would try that first and remove any splitters etc and plug into one tv, rescan and see what if anything you have.
With the signal you have you should be good. Then report back. Then, I would change out the cabling to RG6 with compression fittings. You can get the stuff at Lowe's for example. If you want to do both, that would do no harm, then you should have confirmed good connections.
How many tv's are you running?
