If you have a tv in the basement to connect , then I suggest putting the antenna on the roof or attic. Tv reception with a indoor antenna will not be good in a basement. As an experiment you can get NON AMPLIFIED indoor antenna and try it at the Tv locations including the basement. If put a Tv antenna in the attic or on the roof , DO NOT use a amplifier. The Tv transmissions are very strong at your location. To get the coax from the basement up to the attic or roof , a sewer vent pipe will go from the basement up to top of the roof , run the coax along the outside of the sewer vent pipe.
