Old 22-Jun-2014, 6:55 AM   #1
mazr
Antenna help, please.
http://www.tvfool.com/?option=com_wr...e1c67c9af84c45
Heres my report using this method: enter your address and click "Map This". Then click on "Satellite" at the top right, zoom in, and put the pointer right over your house. Change the antenna height from the default of "10" to "20". When the map updates click on "Make Radar Plot" on the top right. A new window will open. Post the link of the new window with the Radar Plot in this thread.
I currently have the Eagle Aspen EASDTV2BUHF. I had it hung on the 2nd level of the house pointing north, which was wrong. Reception was OK but not great.
Will this antenna work pointing the correct direction or should I go with something else? And what kind of mounting hardware do I need. Chimney mount or tripod is fine. I'll only be using this on 1 TV.
Thanks for the help in advance.
mazr is offline   Reply With Quote
