Old 21-Jun-2014, 11:07 PM   #1
ptgOTA
Antenna upgrade time? - recommendations
I've been using two antennas on my balcony at my apartment for the last 5 years and they've worked ok, but not great, and it seems like everything has died out. I used to get some stations clear for a bit sometimes and then interference would ruin everything completely. Whether the interference was from a passing car or a neighbor using some electrical device like a hair dryer or vacuum or something else. It's hard to tell if the problem is that I'm not getting enough strong and consistent signal or if I need to just upgrade everything(antennas, preamp, and cables) so that I would have more gain and much less loss.
Here's what I have right now...
ClearStream 4 from Antennas Direct
ClearStream 5 from Antennas Direct
Older normal RG59 coax cables
Winegard Preamplifier MODEL AP 8700
Low Pass Filter from Radio Shack
FM Band Rejection Filter from Antennas Direct
Here's my signal report...
http://www.tvfool.com/?option=com_wr...e1c6a28eb0d94b
I really only want to get channels 2-11.
I was also debating on getting RG6 Quad Shield cables to maybe also help cut down any interference I'm picking up since the majority of the cables are outside on my balcony.
I wish I wasn't in the deep-fringe area.
Let me know what you all think that I should do or change.
Thanks for your time
ptgOTA is offline   Reply With Quote
