Outdoor mounting will improve your chances for success. However, your report suggests that an indoor antenna can work if your home's construction does not include signal blocking/reflecting materials.
Several similar antennas to consider, RCA ANT-751, Channel Master CM-2016 and Antennacraft HBU-11 or HBU-22.
A passive splitter such as the Ideal 85-133 or 85-333 and reasonable lengths of coax cable should be able to deliver enough signal to three sets without amplification.
