Are you losing both VHF and UHF?
Which stations specifically are you losing first?
Please provide more info on your amp. This might be an odd case where an amp upgrade to low-noise might be helpful.
Have you checked your aim if it has been some time since it was installed? 149 - 162 but I would be leaning a bit to 162 if those were desirable. 157 degrees or so. Presuming 25 is not worth sacrificing others.
You have a lot of co-channel issues as well.
