Old 20-Jun-2014, 3:35 AM   #3
Pete Higgins
Pete Higgins's Avatar
rabbit73,
Did you take an extended vacation?
Great to see you back posting -missed your posts.
Pete
astorie,
If you can post a link to an accurate TV Fool report for your address the experts can better assist you. It won’t reveal your actual address when others use it.
One last thought, if you have access to a computer, bring up your address in Google Earth and using the <Tools, Ruler, Line Tab> draw a line from your house along the degrees TRUE indicated for the stations of interest. That may help you pick an unobstructed antenna location to minimize degradation from trees and other nearby obstructions. TV Fool lists bearings in both TRUE & Magnetic so make sure you pick from the column labeled TRUE because thats what Google Earth uses.
