Thanks timgr. While I have an interest in the subject, I'm not a licensed electrician or inspector.
If one was to install an antenna in a tree, you'll want to consider using coax with a messenger wire molded into the jacket. You see this type used by the cable TV company from the pole to the house. The messenger is able to serve two purposes. First, it is a strong supporting member and second, it can be used as a grounding conductor between an antenna mast and the electrical service ground.
