					Originally Posted by  pat191
				While I was thinking about mounting in a tall tree, all I could think of
was lightning
 You should ground the antenna in anticipation of lightning strike, regardless of whether its on the roof or in a tree. You also isolate the feed-in from lightning. This has been discussed a lot here.
https://www.google.com/?gws_rd=ssl#q...+and+grounding
Member GroundUrMast knows a lot about this ... I expect he will reply. As I recall, he points to this thread
http://forum.tvfool.com/showthread.php?t=901 as a primer on the subject.
