Old 18-Jun-2014, 8:54 AM   #4
Above the Peak of the Roof install a
http://www.channelmasterstore.com
CM4228HD UHF antenna aimed at about 277 degree magnetic compass direction.
Here is how to aim antennas
http://www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Here are some above the peak of roof antenna mounts.
Install the , ronard(911) , 5 foot tripod antenna mount.
Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com.
Home Depot has , 10 foot 6 inch lengths , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast pipe , the cost is low at about 10 dollars.
Install a
CM7778 preamplifier.
For 1 Tv use No splitter.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at
http://www.hollandelectronics.com
Or
http://www.amazon.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstruction including your own roof and building.
Absorbing and Blocking Reception.
Multi-Path Reflecting = Tv Signals Bouncing All Around.
The Best Practice for Reliable Reception is to install antenna at a location that has the least amount to no amount of obstructions of any type or kind in directions of reception including your own roof and building.
Directions of reception at your location are , West , East , South East.
