Old 10-Dec-2010, 6:57 PM   #2
Originally Posted by dprljackson View Post
I'd appreciate any help I can get. I really want to pick up fox.
David
Fox is coming from 110° and weaker, the others from 54°-83° and stronger. The FOX antenna should be on the roof. There is no one antenna solution that does not require a rotator.
I'd aim the HBU33 at about 69° and the older antenna at 110° and then play with combining them. At first try a splitter backwards. Next consider an A/B switch. Other options are a Jointenna for channel 47 to combine the two antennas and a rotator on the HBU-33.
