Old 16-Jun-2014, 11:45 PM   #6
For reception of these Digital Broadcast Tv Stations/Channels.
WWKH-CA , Real UHF channel 47 , IND. and Retro Tv Network and Live Well Network.
WPXI , Real UHF band channel 23 , NBC and Me-Tv.
WWCP-DT , Real VHF high band channel 8 , FOX and ABC.
WNPB-Tv , Real UHF band channel 33 , PBS Networks.
KDKA-TV , Real UHF band channel 31 , CBS.
The smallest antenna I can recommend is a
http://www.antennacraft.net
HBU11K antenna
installed Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , East North East and South South West.
Aim the HBU11K antenna at about 208 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Test reception without a antenna system amplifier.
If a amplifier is required then install a , Antenna Craft , 10G201 preamp.
A , HBU33 antenna installed above the Peak of the Roof will be better for reception.
If a antenna system amplifier is required then install a , Antenna Craft . 10G201 preamplifier.
Here are some and not all antenna mounts that do not make holes in the roof.
Install the , ronard(4560) , eave antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218 , ronard(2224) .
http://www.ronard.com.
A Tv Antenna that is Designed to Look Like a small satellite dish is the
http://antennacraft.net
HDX1000 Broadcast Tv Antenna.
The HDX1000 will also be install Above the Peak of the Roof so that the Roof and Building Are Not , obstructing , impeding , blocking , reception in the directions of , East North East , South South West.
The HDX1000 will also be aimed at about 208 degree magnetic compass direction.
The HDX1000 has a built in amplifier so a added amplifier is not required.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind including your own roof and building in the directions of reception.
Last edited by teleview; 17-Jun-2014 at 6:03 AM. Reason: Clarify information and typos.
