Old 16-Jun-2014, 10:29 PM   #4
Here are some ways to install the antennas higher.
http://www.ronard.com/712.html.
Ronard , (712-50-10) , 10 foot tripod antenna mount.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , makes good antenna mast pipe , the price is low at about 10 dollars.
http://www.3starinc.com.
Has Push Up Poles that can be mounted at the peak of the roof , and then Guy Wired.
http://www.palcoelectronics.com/pe300.aspx.
Has , Free Standing , No Guy Wires , Light Weight Aluminum , Lay Over , Towers.
Can do Antenna Install and Adjustments Standing On the Ground.
Install the DB8e UHF channels antenna aimed at about 296 degree magnetic compass direction.
Remove the McLapp antenna and install a ,
http://www.antennacraft.net
Y10-7-13 VHF high band antenna.
If the CM7778 preamp is the old type discontinued separate UHF/VHF inputs preamp then connect the DB8e antenna to the UHF input of preamp and the VHF antenna to the VHF input of preamp.
If the CM7778 preamp is the New CM7778 preamp that has 1 input , then use a ,
Holland Electronics , UVSJ = UHF/VHF - Separator/Joiner.
http://www.hollandelectronics.com.
Connect the DB8e to the UHF connection of the UVSJ.
Connect the Y10-7-13 to the VHF connection of the UVSJ.
The single input of the CM7778 preamp is connected the the remaining connection of the UVSJ.
The coax lengths do not need to be the same length when connecting with a UVSJ.
Install the DB8e about +3 feet above the Y10-7-13 if installing on the same antenna mast.
Aim the DB8e antenna at about 296 degree magnetic compass direction.
Aim the Y10-7-13 antenna at about 310 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do no trust a , cell phone , tablet and etc. compass.
Last edited by teleview; 17-Jun-2014 at 4:12 PM. Reason: Clarify information and typos.
