Old 16-Jun-2014, 5:11 PM   #4
The HFS splitters are Power passing splitters and have the advantage of passing power through the splitter in one direction , using a internal diode.
Passing power in one direction prevents
DC voltage/current of a antenna system amplifier
from back feeding through coax lines to other devices connected to the antenna system.
If a splitter is used that does not pass power through the splitter
then All Parts of the amplifier must be before the input of the splitter.
