Hey guys,
Thank you very much for your thoughts. Currently the coax cable (internet) feed is routed into the unfinished basement and this is where our splitter for every currently wired room is located. I'm tempted to go with the individual antennas just because the setup would be soooo convenient, but I think I do prefer the idea of having a single mount upstairs, out of site. However, I'll have to find a way to run the cabling from the attic down past the 2nd and first floors and into the basement. Could the length of that run potentially be problematic?
As an aside, the unfinished basement is a walk out daylight one with the walk out side conveniently facing pretty much exactly where the antenna(s) should point. Three sides of the basement are cinder block interior with brick exterior, but that back side is wood framing, windows, and unbacked insulation.
I suppose I could put that larger single antenna in the basement first just to see how reception would be before affixing permanently in the attic.
