Old 16-Jun-2014, 12:22 AM   #4
Flint Ridge
Junior Member Wannabe
KOVR is UHF, but it is also a strong Line Of Sight station.
Could this be one of the situations where a DB8e could be used? It has the capability to open up the beam width. Some experimenting could be done there. Then the standard Y10-7-13 for the HiVHF side? Aimed around 240 degrees. (Presuming channel 3 and 2 are not needed? If so, then that is LoVHF and further complicates things.) Combined with the RCA PRIMA amp.
Flint Ridge is offline   Reply With Quote
