Old 15-Jun-2014, 7:48 PM   #1
smokinfish
Dallas, TX started of great, but now losing reception
I'm new here, but I cut the cord about one year ago. In the beginning I had great reception. But around November of last year Channel 11 CBS started to come in with distortion at times. Then in just the last month Fox 4 started to do the same thing!
My setup is a TiVo Roamio and 3 TiVo minis, Winegard HDA-100 distribution amplifier, EZ HD antenna.
My TiVo Roamio has a 6ft coax run to a wall outlet, then the wall outlet has about a 15ft coax run to the attic where it ties into the HDA-100, then from the HDA-100 there is a 25ft coax run to the antenna in the back of the house (west). My house faces east in the front and west in the back. The antenna is mounted on a gray conduit pole that is attached to the rafters in the attic ceiling and the attic floor. The antenna is pointing south east.
The TiVo minis share tuners on the main TiVo Roamio through the Ethernet. There are usually no more then two tuners running at a time.
I'm basically 13 - 15.5 miles from the big four stations.
My signal analysis:
http://www.tvfool.com/?option=com_wr...e1c6efe7c1a7be
Any idea why my signal is starting to distort? Have the stations changed anything? Anyone else having similar problems? Should I get a different antenna?
Any help would be greatly appreciated I love not having a cable bill. But, it's frustrating to see all the distortion on your favorite shows. Some are in watchable.
Thanks!
smokinfish is offline   Reply With Quote
