I am humbled , just got back from re making my connections at the grounding block. They were quite corroded and black inside the threaded area.
Now I've got all my channels back from before the wicked rainstorm.
There is some white residue on the grounding block threads but it doesn't seem to effect the signal. Easier to swap out than clean?
Is there anything else I can seal up the connections with until I can get Coax-seal? BTW these connections never "see" direct sunlight, and I have " drip coils" in the connections. Guess drip coils aren't the end all!
Thanks folks I'll never doubt you again!
Are there weather tight crimp on connections like what my satellite tv tech used? They seem to hold up after 10+ years mounted at the same place as my off air connections are.
